Activity Forums VEGAS Pro Reply to earlier Vegas 9.0c HD render issues posts
  • Reply to earlier Vegas 9.0c HD render issues posts
    Posted by Chris Young on March 3, 2010 at 8:09 am
    If you are talking about HD MXF files then yes Vegas 9.0c (32 or 64-bit) has major issues rendering. Doing one-hour weekly TV shows in HD and trying to put them out as 1920×1080 or 1440×1080 MXFs has been a disaster. If you watch the ram consumption in task manager you will see Vegas slowly consume all available ram at which point it just stops, 0% CPU usage and choked on 11.1GB of ram on a 12GB 3.07Mhz i7 system, five systems in all. In our cases that’s around 37-40% of the timeline duration. Sony has been aware of this issue for quite some time now so hopefully it is fixed soon.
    Here is one current work-around which has saved our bacon. With the network shows I am now rendering the segments out as Cineform HD, having upgraded to the latest 64-bit compatible version. Since working with the Cineform codec our problems have gone. I can now render out an entire complex 12 to 14 layer one hour HD show in one piece and ram usage never goes above 2.8-3.2GB. Once the full hour is rendered out in Cineform I can then render out a one-hour 1920x1080i 50-mbit MXF for print to disc for network delivery. Seeing that Vegas can render a one hour MXF without too much difficulty it appear that the real problem lies somewhere in the Sony MXF file reader code and not with the renderer.
    Chris Young
    CYV Productions
    Sydney
    Martin Phillips replied 16 years, 5 months ago 2 Members · 1 Reply
  • Martin Phillips
    March 3, 2010 at 8:47 am
    Hi Chris,
    Sorry to jump in on your thread like this, but do you have a personal email that i could drop you a message on…. nothing strange i promise you…!!
    Regards
    Martin Phillips
