Activity Forums Apple Final Cut Pro Legacy Replicating 4×3 center extraction
  • Replicating 4×3 center extraction
    Posted by Russell on August 24, 2006 at 7:23 pm
    Greetings,
    I have a 16×9 project. I want to replicate what it will look like if I do a 4×3 center extraction without pan and scan. I tried placing my project in a 4×3 timeline, but it is still letterboxed. Is there a way to do this? I was also thinking of creating a matte that would accomplish this goal but am not sure how to do it. I realize I may have to re-render the entire movie if this is the solution…. Any suggestions?
    Russell
    Final Cut Pro HD
    Russell replied 20 years, 1 month ago 3 Members · 4 Replies
  • Aaron Neitz
    August 24, 2006 at 7:25 pm
    motion tab – scale until you lose the letterbox.. i think 133% should do
  • Mark Maness
    August 24, 2006 at 9:55 pm
    What capture card are you using?
    If you have an AJA Kona series card, you can send your 16:9 timeline to tape and use the Kona control panel to select a 4:3 center punch to write to tape. This will give you the best results.
    If this is going to DVD and you don’t have a Kona card, you can always blow it up to 133% in the Motion tab. BUT this is going to degrade your timeline just like taking a JPEG picture and blowing it up to 133%. But it may be acceptable for DVD if that’s your final output.
  • Russell
    August 25, 2006 at 3:14 pm
    This works. Thanks very much for the help!
  • Russell
    August 25, 2006 at 3:15 pm
    Hi Wayne,
    Thanks for the information. Im just watching it for my own reference, so the motion tab solution works great.
    Russell
