Activity Forums Adobe After Effects replacing video in a comp
  • replacing video in a comp
    Posted by Scott Carroll on May 21, 2006 at 9:09 pm
    Hi all
    I have made a composition with several layers and now want to change the media in one of the layers, but retain all the attributes associated with it.(ie scale position etc)
    Can this be done?
    Scott
    Ron Lindeboom replied 20 years, 4 months ago 5 Members · 6 Replies
  • Enzo Tedeschi
    May 21, 2006 at 9:27 pm
    Import your replacement media.
    Select it in the project window.
    Select the layer you want to replace in the timeline.
    Ctrl + Alt + /
    This will swap the layer in the timeline for what you have selected in the project window without affecting any layer attributes.
    Enzo Tedeschi
    ____________________________
    Editor
    Sydney, Australia
  • Deadittex
    May 26, 2006 at 12:43 am
    Or if you have AE 7 you can go to your project window, click on the media, highlight it as it were, then sinply go into the file pull down menue go to replace media and clck there then find the new media and replace it
  • Julian Sixx
    May 26, 2006 at 2:57 pm
    [Enzo Tedeschi] “Ctrl + Alt + /”
    No,it’s Ctrl + Alt + \
  • Enzo Tedeschi
    May 27, 2006 at 1:38 am
    Not unless you’re using a different keyboard to me, julian06. Just double checked it on my Powerbook.
    It’s the / key right next to the fullstop at the bottom of the keyboard.
    Enzo Tedeschi
    Editor
    Sydney, Australia
  • Julian Sixx
    May 27, 2006 at 9:07 am
    [Enzo Tedeschi] “Not unless you’re using a different keyboard to me”
    Yes,I do
    Sorry mate,your shortcut didn’t work for me 🙂
    I’m on Pc
    [Enzo Tedeschi] “It’s the / key right next to the fullstop at the bottom of the keyboard.”
    well,on my keybord there is the \ key
    never mind:)
  • Ron Lindeboom
    May 27, 2006 at 1:50 pm
    The / key that Enzo is talking about is the one that is on the same key as your ? key.
    Best regards,
    Ron Lindeboom
