Activity › Forums › Adobe Photoshop › Replacing image.
  • Replacing image.
    Posted by Scott Davis on August 22, 2007 at 5:17 pm
    I’ve created a menu for DVDSP in Photoshop. I want to create a secondary menu that is exactly the same except for the images used for the buttons. Is there an easy way to replace the current button image with a different image and maintain all the attributes of the original layer (ie cropping, scaling, feather, etc)
    Scott Davis
    Scott Davis
    Richard Harrington replied 19 years, 1 month ago 2 Members · 3 Replies
  • Richard Harrington
    August 28, 2007 at 1:11 am
    Use Smart Objects for the layer…. then apply layer styles…
    You can replace the contents of a Smart Object.
    You may also want to attach a mask but unlink it
  • Scott Davis
    August 28, 2007 at 1:25 pm
    Richard thanks, (for the reply and I’ve been going through your podcast). I tried Smart Objects. I got it to kind of work. I could not get it to “take” the scaling, attributes or the cropping attributes. I will try some more today though.
    Scott Davis
    Scott Davis
    August 30, 2007 at 11:21 am
    Add a Layer Mask to the Layer (outside the Smart Object)
    Unlink it (click the chain icon)
    That will get you closer =)
    You also may want to explore using Data Sets as a way to do this
    Richard M. Harrington, PMP
    Author: Photoshop for Video, Understanding Adobe Photoshop, and ATS:iWork
