Activity › Forums › Adobe After Effects › Replacing footage in Premiere with an AE composition for slow-mo (CS6)
  • Replacing footage in Premiere with an AE composition for slow-mo (CS6)
    Posted by Mladen Ilic on October 11, 2012 at 9:51 am
    This option rocks! But I have a problem when I replace footage in Premiere with an AE composition for adding effects like Timewarp or Twixtor. For example, I’m replacing an edited part of a clip whose duration is 5 seconds and goes from 0:35 to 0:40 sec of the entire movie clip, but, the instant I put a twixtor or timewarp effect the timeline gets screwed. It doesn’t go from 0:35 to 0:40 sec, but God knows from where, for example it suddenly starts from the beginning or whatever and everything becomes pointless.
    I found a way around this problem by exporting the clip in premiere, putting it again in premiere instead of the edited part and then replacing it, as a whole, with an AE composition…
    But there has to be a simpler way to make this work?
    Thanks everybody,
    Mladen Ilic
    Mladen Ilic replied 13 years, 11 months ago 1 Member · 0 Replies
  • 0 Replies
