Activity › Forums › Adobe After Effects › Replacing footage in Premiere with an AE composition for slow-mo (CS6)
  • Replacing footage in Premiere with an AE composition for slow-mo (CS6)
    Posted by Mladen Ilic on October 24, 2012 at 1:06 pm
    I have a problem when I replace the footage in Premiere with an AE composition for adding Twixtor slow-motion effect. For example, I’m replacing an edited part of a clip whose duration is 5 seconds and goes from 0:35 to 0:40 sec of the entire movie clip, but, the instant I put a twixtor or timewarp effect in AE the timeline gets screwed. It doesn’t go from 0:35 to 0:40 sec, but God knows from where, and everything becomes pointless. To tell it more simply, when I apply twixtor in AE, instead of those exact 5 seconds that I need and have sent to AE, I get some other random 5 seconds from that movie clip?!?
    I found a way around this problem by exporting the clip in premiere, putting it again in premiere instead of the edited part and then replacing it, as a whole, with an AE composition…
    But there has to be a simpler way to make this work?
    Thanks everybody,
    Mladen Ilic
    Mladen Ilic replied 13 years, 11 months ago 2 Members · 2 Replies
  • Pierre Jasmin
    October 24, 2012 at 8:04 pm
    Is this Right-Click on clip in timeline and Replace with AE Composition?
    Did you trim the in-point in Premiere?
    You can also apply Twixtor in Premiere if you want.
    https://library.creativecow.net/tutorials/revisionfx/2
    Pierre
  • Mladen Ilic
    October 25, 2012 at 7:53 am
    Yes it is Right-Click on clip in timeline and Replace with AE Composition.
    The clip is trimmed, if you mean if I edited it (using only a small part that I need).
    Mladen
