Activity Forums Adobe After Effects Replacing footage in a template layer
  • Replacing footage in a template layer
    Posted by Gary Woloszyn on August 23, 2014 at 6:21 pm
    I use Motion so I am a bit of a newbie to After Effects…
    I want to reuse a complex scene with camera movement, lights, keyframes, etc. from a template. Then I want to change the image in that scene.
    Do I make a new layer, copy and paste the old layer, then replace the footage using ALT+drag?
    Thanks much
    Hannes Andersson replied 12 years, 1 month ago 2 Members · 1 Reply
  • Hannes Andersson
    August 24, 2014 at 3:52 pm
    if you in “project” rightclick on the footage you want to change you can choose “replace” and select the file you want
    Donuan
    Digital Artist / Film Maker / VJ / Animator
    https://donuan.tv
