Activity Forums Apple Final Cut Pro Legacy “replacing” clips with transitions…
  • “replacing” clips with transitions…
    Posted by J. Tad newberry on August 21, 2007 at 8:23 pm
    i can’t do it. i have no problem doing a “Replace” with a clip that does not start with a transition from another clip, but can’t do it with a transition regardless if i try it with the playhead parked at the beginning, middle, or end of the transition. i’ve also tried it a frame before and after the beginning and end. in all ways i get “insufficient content for edit”.
    thanks again!
    mh
    J. Tad newberry replied 19 years ago 1 Member · 1 Reply
  • J. Tad newberry
    August 28, 2007 at 5:06 pm
    anyone have an idea on this? just checking…
    thanks again!
    mh
