Activity › Forums › Apple Final Cut Pro Legacy › Replacing AVCHD with Prores without reimporting
Posted by Anette Olsen on August 20, 2012 at 10:26 amI just logged and transferred a bunch of AVCHD-files fra my SDcart into FCP and forgot to chose Apple ProRes 422 in the Import Preferences window.
Can I replace those files without reimporting?And if yes, how to do?
Rafael Amador replied 14 years ago 4 Members · 6 Replies -
Shane Ross
August 20, 2012 at 5:17 pmWell, you are going to have to convert the footage to ProRes somehow. How can you do that without logging and transferring again?
How did you bring in the footage in the first place? what format?
Shane
Little Frog Post
Read my blog, Little Frog in High Def -
Joseph Owens
August 20, 2012 at 8:09 pmI’d try a Batch Export…
jPo
“I always pass on free advice — its never of any use to me” Oscar Wilde.
Anette Olsen
August 21, 2012 at 9:41 amok, thanks. I imported the files as Apple Intermediate. I’ll take a deep breath and import again.
Rafael Amador
August 21, 2012 at 12:22 pmProres is the default format when using L&T with AVCHD footage, so I guess your stuff is already Prores.
Check it in the Browser.
rafael -
Rafael Amador
August 23, 2012 at 4:57 amYou better L&T again instead of re-converting the AIC files to Prores.
The AIC is a very lossy and you will end up with a crap of footage.
rafael
