Activity › Forums › Maxon Cinema 4D › replacing all textures in one scene with a single texture
  • replacing all textures in one scene with a single texture
    Posted by Joe Carusoe on June 14, 2005 at 1:10 am
    i’ve got a fairly complicated city file, 50 or so textures. i’d like to replace them all with one texture. is there an easy way to do this?
    thanks!
    Ljubomir Kremenović replied 9 years, 2 months ago 7 Members · 7 Replies
  • 7 Replies
  • Arndt Von koenigsmarck
    June 14, 2005 at 8:25 am
    Delete all texture tags, group all objects under a Null object and asign your texture to that Null object.
    Kind regards,
    Arndt von Koenigsmarck
    https://www.vreel-3d.de
    https://www.vonkoenigsmarck.de
  • Lennart Wåhlin
    June 14, 2005 at 11:21 am
    Or select the materials to be swapped in the MaterialManager. Then in MM go Function > SelectTextureTags/Objects.
    In AM drag in the new material to be used.
    Cheers
    Lennart
  • Adam Trachtenberg
    June 14, 2005 at 2:40 pm
    Or… Object Manager>Objects>Search>Tags>Texture Tags. Then drag the new material into the texture link box in the Attributes Manager.
  • Joe Carusoe
    June 14, 2005 at 7:03 pm
    thanks!
  • Grant Henderson
    October 20, 2016 at 10:22 am
    1 – Right click on the current material being used in the materials bar
    2 – Click ‘Select Texture Tags/Objects’ (they should highlight on the objects being used)
    3 – Right Click on the new texture you wish to replace with and choose ‘Apply’
    4 – The new textures should be hierarchically above the old texture.
    5 – Right click on the old material being used in the materials bar and re-select
    6 – Click Delete, this will remove them all from the objects they are on…
  • Demian Krentz
    June 6, 2017 at 8:15 pm
    Adam’s method seems more universal. The action path he listed needs updating though.
    1. Select old material in Material Manager.
    2. Right click and choose Select Texture Tags/Objects
    3. Drag new texture from MM into Material field of Attribute Manager.
    4. If necessary, delete old material.
  • Ljubomir Kremenović
    July 26, 2017 at 4:10 pm
    Thanks u are a life saver
