Activity Forums Adobe After Effects replacing a comp – but offset
  • replacing a comp – but offset
    Posted by Scott G on November 10, 2005 at 3:36 am
    hi,
    can anyone suggest a quick way of replacing a comp when the two comps aren’t the same size?
    the bottom-right corners match up, but apart from that they’re odd sizes, not neat like 1/4 or 1/8 or 1/3.
    do i just have to get out my calculators and replace, then compensate by shifting the anchor point etc?
    apologies if this is a silly q, i have been doing some very late nights and my brain is just about fried.
    Andrew Yoole replied 20 years, 10 months ago 2 Members · 1 Reply
  • Andrew Yoole
    November 10, 2005 at 7:35 am
    If I understand right you have a Main Comp which contains a precomp (lets call it Precomp 1). You want to replace Precomp 1 with Precomp 2, which is a different size to precomp 1.
    I’d create a new comp, Precomp 3, which is the same size as precomp 1. Place Precomp 2 in Precomp 3 and resize to fill the comp. Now replace Precomp 1 in the Main Comp with Precomp 3.
