Activity Forums Apple Final Cut Pro Legacy Replacing a clip
  • Replacing a clip
    Posted by Kevin Camin on October 9, 2011 at 9:36 pm
    If I have a clip in the timeline and I want to just swap out the clip, is there a way to do that? Because I want to retain all the filters and Motion parameters and have them transferred to the new clip.
    Best regards,
    Kevin Camin
    Stephen Smith replied 14 years, 11 months ago 3 Members · 2 Replies
  • Neil Patience
    October 9, 2011 at 10:19 pm
    Probably the easiest way is to right click on your existing clip in the timeline and select copy.
    Then edit in your new clip.
    Then right click on the new clip and select paste attributes.
    You can then select which attributes from the old clip to copy across.
    So perhaps in your case that will be Basic Motion and Filters.
    But you can select other parameters too like crop etc, just select the ones that are relevant to your clip that you want to retain.
    Then the new clip will have all of the attributes and filters from the old one.
    best wishes
    Neil
    http://www.patience.tv
  • Stephen Smith
    October 10, 2011 at 3:48 pm
    Neil’s way is easier and recommended…but to swap it you can select the clip you want and hit the command and C keys to copy it. Then right clip on the clip you want to replace and choose Paste Attributes. Then choose Content. Content will take the last clip and past it into the new clip. Because of varying lengths it is easier to paste the attributes such as Basic Motion and Filters though.
    Stephen Smith
    Utah Video Productions
    Check out my Motion Tutorials
