Activity › Forums › Storage & Archiving › Replacing a bad drive in a Lacie 4big striped RAID 5
  • Replacing a bad drive in a Lacie 4big striped RAID 5
    Posted by Mike Weber on March 2, 2015 at 5:55 pm
    Hello
    I have a Lacie 4big Quadra 8TB drive, striped RAID 5. (4 x 2TB drives inside). Connected to a Mac Pro running OS 10.6.8. The Lacie RAID is about 4 years old.
    A few days ago it started performing very slowly, and sometimes failing altogether when reading and/or writing. Iooked in the back, and the light by Drive #2 was blinking red-blue-red-blue.
    I shut down everything, pulled out the bad drive, restarted, and the RAID still shows up on the desktop because it was set to RAID5. I can access the files fine, but I know I need to replace the bad drive to regain my redundancy. The big circle light on the front of the drive now flashes red-blue-red-blue.
    If I buy a 2TB drive and install it where the bad drive used to be, what will happen? Will the files that used to be on the bad drive automatically reconstitute themselves on the new drive? Or do I need to do something to make this happen.
    Or will I need to erase/reformat the whole thing to get back to normal? This wouldn’t be the end of the world, because the files on the drive are also backed up on another system in a different building, so we are covered every which way.
    Thank you for your advice –
    Mike
    Mike Weber replied 11 years, 6 months ago 3 Members · 3 Replies
  • Simon Blackledge
    March 3, 2015 at 3:39 pm
    If you loose a drive in RAID5 you do NOT have to reformat if the rebuild is successful. That would be RAID0
    PAGE 20 for replacing a disk.
    https://www.lacie.com/download/manual/4big_Quadra_en.pdf
    Blinking red/blue/red/blue says heat issue.
    Looking at manual there is no RAID application just a switch on the unit so I suspect it will AUTO rebuild.
    Make sure you replace exactly like for like – Manufacture / Model / Capacity – Firmware should match but you maybe ok.
    Hope that help.
    s
  • Rainer Wirth
    March 5, 2015 at 10:39 am
    Just insert the new drive and it will auto rebuilt.
    You need exactly the same drive. Normally it would be a 2TB Hitachi HDS 722020ALA330
    cheers
    Rainer
    factstory
    Rainer Wirth
    phone_0049-177-2156086
    Mac pro 8core
    Adobe,FCP,Avid
    several raid systems
  • Mike Weber
    March 5, 2015 at 7:09 pm
    Great, thanks guys for your advice. I ordered a replacement drive directly from Lacie, should arrive today.
