Activity Forums Square Box CatDV replaceSettings Failed (Packet for query is too large)
  • replaceSettings Failed (Packet for query is too large)
    Posted by Shane Johnson on August 13, 2014 at 9:45 pm
    I got an error today when trying to update the Details Panel (adding and removing a field). I’ve never seen this before and am unsure where (or if I SHOULD) update the variable settings. Anybody know how to fix this?
    replaceSettings Failed (Packet for query is too large (1196974 > 1048576). You can change the value on the server by setting the max_allowed_packet’ variable.)
    Bryson Jones replied 12 years ago 3 Members · 7 Replies
  • 7 Replies
  • John Vaudin
    August 14, 2014 at 8:37 am
    It’s not uncommon to need to increase max_allowed_packet in you my.conf or my.ini file. I ususally set it to 16M.
  • Shane Johnson
    August 14, 2014 at 3:27 pm
    Hmm, I’m not sure where to find either of those files and I did a search on the whole server.
    Where do I find those files?
  • Bryson Jones
    August 14, 2014 at 10:50 pm
    I have the info Shane, trying to get a quick way to share it to the world.
    That’s a MySQL admin thing and you may want your integrator to do it, but I’ll post the steps as soon as I can. (we’re doing a web re-work.)
    bryson
    bryson “at” northshoreautomation.com
  • John Vaudin
    August 15, 2014 at 9:20 am
    Sorry – finger trouble – I of course meant my.cnf (on a Mac). Its location can vary but its usually /etc/my.cnf.
  • Bryson Jones
    August 15, 2014 at 5:20 pm
    Hey guys, this is a quick doc we keep in our internal wiki for our field techs.
    I’m posting it publicly with the hope that if it helps you, you take a look at Akomi as payback. 😉
    Catdv-Server MySql max_allowed_packet setting
    bryson
  • Shane Johnson
    August 15, 2014 at 6:08 pm
    Squarebox actually logged into our server and the reason I couldn’t find that setting was because they needed to ADD the line into one of the files… Not sure how it went missing, but it is fixed now.
    Thanks a ton for your help!
  • Bryson Jones
    August 15, 2014 at 7:01 pm
    I do need to add that one.
    Often it’s not in there but you can just add the line. As I understand it, as long as the doc looks similar to the example shown you’re good.
    bryson
