Activity › Forums › Adobe After Effects › Replacement of footage depending on last frame
  • Replacement of footage depending on last frame
    Posted by Jan Rous on December 1, 2024 at 11:52 pm
    Hello guys.
    I have created quite complex template where I need to do something special.
    Imagine a simple composition with duration of 100f and 50f placeholder in it which ends with comp last frame (so from 51 to 100). Now when you replace that placeholder with longer footage (such as 90f), it prolonges the layer to the frame 140. I need that last frame to stay on place . So the footage will extend to the start instead. Is that possible?
    Jan Rous replied 1 year, 9 months ago 1 Member · 0 Replies
  • 0 Replies
