Activity › Forums › Broadcasting › Replacement for SGI monitor
  • Replacement for SGI monitor
    Posted by Mathieu Marano on February 8, 2008 at 8:09 pm
    Hi guys,
    I have a Flame workstation running on SGI. I have a GDM FW9011 SGI display attached to it with RGB HD VD cables. I am trying to find a display to replace it that would also have DVI input for a second windows-based station. I would like to be able to use the same display for both.
    Any suggestion?
    Mathieu Marano
    Del Holford replied 18 years, 7 months ago 2 Members · 1 Reply
  • Del Holford
    February 11, 2008 at 6:31 pm
    We recently replaced our SGI crt in smoke with an HP 2335 LCD and it works fine but the Octane2 needs sync on green so it uses the 15 pin with an adapter. That only leaves RGB and composite in on RCA connectors. That might work for you if the Windoze machine can output to that. I think the 23″ version is now a 24″ version but is otherwise the same.
    https://h18000.www1.hp.com/products/quickspecs/12450_na/12450_na.PDF HTH
    Del
    fire*, smoke*, photoshopCS3
    Charlotte Public Television
    del underscore edits at wtvi dot org
