Activity › Forums › Adobe After Effects › replacement Footage/Template Question
Posted by Durwood Hibbard on October 4, 2011 at 9:17 pmI am working on a project that not everything has been shot yet. I have time to work on the set up now. What is the best way to set up a project so that I can have the project done, minus the footage, and then be able to drop the footage in once it is shot?
Durwood Hibbard replied 14 years, 11 months ago 4 Members · 6 Replies -
Walter Soyka
October 4, 2011 at 9:26 pmYou could use placeholders [link].
Alternately, you could create a comp in which you will place your final footage. You could use scratch footage or even a still.
You can use the Replace footage command to globally swap a piece of footage out for another one, or you can select a layer in the timeline to replace and Alt-drag a new item from the project panel onto your selected layer.
Walter Soyka
Creative Cow Forum Host: Live & Stage Events -
Tudor “ted” jelescu
October 4, 2011 at 9:27 pmIt depends a lot on what you need to do- your question is very generic, be more specific, give examples so we can understand what your project is. Are you just animating graphics over footage, creating elements to complete a shot, chroma, other…?
Tudor “Ted” Jelescu
Senior VFX Artist -
Durwood Hibbard
October 4, 2011 at 9:47 pm -
Ben G unguren
October 5, 2011 at 3:48 amIn that case, my suggestion is to make a composition for each [future] video clip. Put a still image in there for now as a reference. Do your animation with all the compositions nested in a new comp. At that point it’s just a question of dropping your footage over the still images in your video comps. Piece of cake. Probably.
Ben Unguren
Motion Graphics & Editing
http://www.mostlydocumentary.comSome contents or functionalities here are not available due to your cookie preferences!This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
Tudor “ted” jelescu
October 5, 2011 at 4:33 pmAs the others suggested you could make a precomp with a still image inside for refference and use that precomp to build your animation. You can then replace the stills with the footage. You can also just use stills and then replace them directly, but the advantage of using precomps is that you can adjust your footage inside the precomp, add effects and color grade without messing with your template.
Tudor “Ted” Jelescu
Senior VFX Artist
