Activity › Forums › Adobe After Effects › Replace text with image while keeping animation settings
  • Replace text with image while keeping animation settings
    Posted by Jason Parks on June 21, 2013 at 3:05 pm
    I’m editing a project that starts with a text animation (text slowly zooms in, then slides off the top of the screen). I’d like to replace the the text with an image (logo), while keeping the same animation the text had. What’s the best way to accomplish this?
    Eric Santiago replied 8 years, 10 months ago 5 Members · 4 Replies
  • John Cuevas
    June 22, 2013 at 12:00 pm
    Take a look at the text animators and copy what was done there to the transformation properties of the text would be the way I would approach it.
    Which text preset are you trying replicate? Also is this something you want to do to the logo as a whole, or to individual letters in the logo, cause that would change the approach some.
    Johnny Cuevas, Editor
    Thinkck.com
    “I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work.”
    —THOMAS EDISON on inventing the light bulb.
  • Raven Bluefeather
    November 9, 2017 at 6:07 pm
    video tutorial?? because following your steps just made stuff worse
  • Roei Tzoref
    November 10, 2017 at 3:38 pm
    what properties are keyframed for your text? if it’s just transform properties of the layer itself (scale, rotation, position) then you could place the image in the exact starting position of the text, parent the image to the text, toggle off the eyeball switch for the text and there you have it.
    Roei Tzoref
    2D/VFX Generalist & Instructor
    ♫ AeBlues Tutorials ♫
    http://www.tzoref.com
  • Eric Santiago
    November 10, 2017 at 4:02 pm
    If its a transform to the layer then a precomp is best.
    At times parenting works too.
    If its actual keyframes applied to the text using Text Presets then no you cant apply that to a different layer.
