Activity › Forums › Adobe After Effects Expressions › Replace Text Expression For Correct Quotation Marks
  • Replace Text Expression For Correct Quotation Marks
    Posted by André Otto on November 26, 2021 at 9:19 pm
    Hi guys, I would like to have an expression that replaces wrong quotation marks set by an editor in a MOGRT used in Premiere Pro.
    In German the corect quotation marks have to look like this: „text“ (option+shift+w and option+2).
    But if you can imagine an editor can’t remember this shortcuts, they simply use shift+2 what results the symbol for inches or seconds (“).
    The difficulty (why I can’t use a simple text replace expression) is that the editor uses the same symbol twice. In front and behind the quote. But I need a result with two different symbols.
    Any ideas? My mail software on the Mac does exactly that what I want automatically.
    Is there a way in counting the wrong symbols and odd numbers result the first lower quotation mark and even numbers the upper one?
    André Otto replied 4 years, 10 months ago 1 Member · 1 Reply
  • André Otto
    December 1, 2021 at 4:07 pm
    Just in case if someone has the same problem, here is what solved my problem very simple:
    txt = text.sourceText;
    txt.replace(/”/,”„”).replace(/”/,”“”).replace(/”/,”„”).replace(/”/,”“”).replace(/’/,”’”).replace(/’/,”’”).replace(/ß/,”ẞ”).replace(/ß/,”ẞ”).replace(/ß/,”ẞ”).replace(/ß/,”ẞ”)
    The expression replaces the wrong signs in the written order: two times for quotation marks followed by two apostrophes and four capital letter ß (what’s very common in German).
    Thats all I have to expect in my case so it will work fine hopefully.
