Activity › Forums › Apple Motion › Replace Footage?
  • Replace Footage?
    Posted by John Felt on July 5, 2008 at 11:47 pm
    Hi all
    I am working on a project where I need to swap out some footage to replace it with other updated footage. The new footage and old footage are the same size, so I just want to be able swap out the old for new. Essentially give all the old property values to the new footage.
    Is there a way to easily just replace footage? It’s fairly simple in After Effects so I figured there would be a way in Motion, but I can’t seem to find it.
    Thank you all for you help. It is always enormously appreciated.
    Thanks, John
    Colin Mcquillan replied 18 years, 2 months ago 2 Members · 2 Replies
  • Colin Mcquillan
    July 6, 2008 at 9:28 pm
    Drag and drop the new footage over top of the old. It will retain all the formating/key frames so on… of the clip it’s replacing.
    Make sure you see a box appear around the lower (old) clip. If you see a line below or above the clip you want to replace, you will only add the new clip to the group, not replace the old clip.
    Colin McQuillan
    Van. B.C.
  • Colin Mcquillan
    July 6, 2008 at 9:50 pm
    Do this in the Layers tab (F4)
    Colin McQuillan
    Van. B.C.
