Activity Forums Avid Media Composer Replace clip w/o affecting Symphony Color Correction
  • Replace clip w/o affecting Symphony Color Correction
    Posted by Michael Buday on August 27, 2018 at 9:51 pm
    Is there a way to replace a clip on the timeline without removing Symphony color correction applied to it? I know with nested/effects I can drill down and replace the underlying native clip w/o removing the effects, but Symphony CC works differently – or am I wrong?
    Right now I’m saving the correction in a memory slot, replacing the clip, then recalling the memory, but this is a lot of work.
    MB
    Shane Ross replied 8 years ago 3 Members · 3 Replies
  • Shane Ross
    August 29, 2018 at 6:39 am
    Sorry for replying late, I forgot to check this when I got in front of my system. I just checked, and no, you can’t step into the color corrections on a Symphony…alas.
    Shane
    Little Frog Post
  • Glenn Sakatch
    August 29, 2018 at 6:44 pm
    can you put the new clip on a new track, and copy the effect from bottom to top track?
    Glenn
  • Shane Ross
    August 29, 2018 at 9:34 pm
    Yes, that you can do
    Shane
    Little Frog Post
