Activity › Forums › Adobe After Effects › Repeat. Repeat. Repeat. Repeat. Repeat.
  • Repeat. Repeat. Repeat. Repeat. Repeat.
    Posted by Henry on September 16, 2005 at 7:16 am
    I’ve got some video footage which I’ve made 50% of it’s original size.
    I know want it to repeat (with a gap between each image) 100’s of time in either direction on the horizontal.
    Like the repeater on 3d stroke – but for video.
    Is there an effect?
    Cheers,
    Henry
    Steve Roberts replied 21 years ago 3 Members · 4 Replies
  • Steve Roberts
    September 16, 2005 at 7:27 am
    Try effect>stylize>Motion Tile. You might want to then apply effect>distort>offset, but it depends on the effect you want.
    Steve
  • Roland R. kahlenberg
    September 16, 2005 at 7:50 am
    It’s going to be a rather huge layer by the time you’re done. I hope you have sufficient RAM to get it done.
    As Steve said, Motion Tile should do the trick for you. Particle Playground’s Grid also does this sort of thing efficiently – but with 100’s?
    Cheers
    Roland Kahlenberg
    broadcastGEMs
    customizable animated backdrops with Adobe After Effects project files
  • Henry
    September 16, 2005 at 7:59 am
    Thanks very much – used motion tile.
    I hate asking (it’s like spoiling the end of a movie) but I am in a hurry!
    Many thanks.
  • Steve Roberts
    September 16, 2005 at 10:24 am
    If you do run out of RAM during the render, access the “Secret” prefs and therein, purge every 5 frames (suggested) during Make Movie.
    To get there, hold down shift when accessing the prefs from the menu, and hold down the shift key until the prefs dialog shows up.
    Steve
