Activity Forums Adobe Photoshop repeat radially, like sun rays?
  • Keith Thomason
    October 7, 2008 at 5:25 am
    Find the exact center of your circle and mark it with guides. Then select the ray you want to copy/rotate and pick the rotate tool. Click the rotate tool once in the center of your circle. Then move your cursor to the ray, hold down the alt key to make a copy while rotating the ray where you want it. Then you can simply use Apple or Command “D” to duplicate what you just did. Keep hitting the Apple/Command “D” until you have finished the radial.
    I hope that made sense.
