Activity Forums Maxon Cinema 4D Repeat last render region
  • Repeat last render region
    Posted by David Wiffen on December 11, 2008 at 2:47 pm
    Hi Everyone,
    Quick and hopefully easy one for you all here. I am just wondering if there’s a way to repeat the last render region you selected. I know there’s interactive render region, but I just find this quite irritating to use and seems to take longer to render.
    I’m making changes to a specific area of my model and keep adjusting textures, so I need to keep quickly rendering just a small section. It’s using sketch and toon so the render is quite slow, hence not wanting to use interative render region.
    Ideally I am hoping someone has made a plugin that allows you to click a button and the last render region you rendered can be rerendered. (or some feature I haven’t discovered!)
    Thanks in advance!
    David Wiffen replied 17 years, 8 months ago 2 Members · 2 Replies
