Activity Forums Audio Repairing Corrupt Recording from H2
  • Repairing Corrupt Recording from H2
    Posted by Rob Haslam on May 20, 2011 at 5:21 pm
    I was wondering if there was any way of repairing a recording from my H2 digital recorder. It recorded directly from the soundboard onto an sd card, but now the file is showing that there are 0kb on the sd card. Any help would be fantastic.
    Rob
    Eric Toline replied 15 years, 4 months ago 3 Members · 2 Replies
  • Bouke Vahl
    May 21, 2011 at 7:23 am
    What bytes do you want to repair if you got zero?
    For a start this is IT work to get at least some data.
    After that, if it is a corrupt clip, use Audacity to read it as raw data.
    hth,
    Bouke
    https://www.videotoolshed.com/
    smart tools for video pros
  • Eric Toline
    May 21, 2011 at 12:49 pm
    Just suggesting possible causes. The feed from the board went dead, you forgot to push the record button, the connection into the recorder got pulled out, you had a bad cable. Can you replicate the setup again and see if the recorder works?
    Eric
