Activity › Forums › Apple OS X › Repair Permissions Trouble
  • Repair Permissions Trouble
    Posted by Jim Roen on April 26, 2006 at 4:30 pm
    I’ve tried repairing permissions and I get a message; “Disk Utility has lost it’s connection with the disk management tool and connot continue. Please quit and relaunch Disk Utility.” I’ve tried it many times.
    Did I screw up really bad? What can I do?
    Jeff Carpenter replied 20 years, 5 months ago 3 Members · 2 Replies
  • Curtis Thompson
    April 26, 2006 at 4:33 pm
    hello…
    try here:
    https://discussions.apple.com/thread.jspa?messageID=2089139
    or google up a few of the phrases from your error and you should see a lot of hits…
    sitruc
  • Jeff Carpenter
    April 26, 2006 at 6:57 pm
    Are you using the most recent iTunes? That article is from a few weeks back when iTunes was causing this problem. It’s a workaround, yes, but since the new version of iTunes came out I haven’t had any problems. Try and update to the newest version and see if that solves it.
    If it doesn’t, then go back to that article.
