Activity › Forums › Blackmagic Design › repair card
  • Daniel Schweinert
    July 20, 2012 at 10:06 am
    What happened?
    If it’s only that small SMT part you can ask your local electronics shop in town. They will do it for a couple of bucks. Though Im not sure if it is a capacitor or resistor. If you can get a pic of a working one you might see which part was there.
  • Roy Smith
    July 20, 2012 at 12:18 pm
    This is a working card if you zoom in you can see the printed circuit are damage. Looking to get fix but money is short
    Thank You
  • Roy Smith
    July 20, 2012 at 12:26 pm
    Would you know where I could get a schematic on the Blackmagic DeckLink HD Extreme 3D board
    Thank You
  • Roy Smith
    July 20, 2012 at 12:28 pm
    Thank You
  • Daniel Schweinert
    July 20, 2012 at 1:26 pm
    Im repairing electronics myself as a hobby and I use parts from old / damaged GPU cards. To me it looks like a 0805 smd capacitor (but Im not 100% sure until I can measure it). You don’t need a complete schematic. Usually a local tech geek in your town could measure the one on the right side and solder a new one there. The part itself costs 2 cents. The whole work shouldn’t cost you more than a cup of coffee.
    Here a youtube video I’ve found how easy it is to resolder a smd capacitor yourself: https://www.youtube.com/watch?v=EWeAOemTY_E
    Capacitor 0805: https://sigma.octopart.com/10856365/image/AVX-0805ZC105KAT2A.jpg
    But you will need a soldering iron with a small tip.
  • Daniel Schweinert
    July 20, 2012 at 1:32 pm
    That said only if the capacitor is damaged.
    If the chip above or the underneath conducting path is damaged than it’s a whole different story. Can’t tell you more from that image. Would need a macro and a more angled view.
  • Roy Smith
    July 20, 2012 at 4:00 pm
    It missing one conducting path that go underneath the chip above. Look like I need to learn how to remove chips from the board.
    Thank You For Your Time
