Activity Forums VEGAS Pro Rendring Probmlems
  • Rendring Probmlems
    Posted by Nick Mok on July 23, 2008 at 7:49 am
    I am using sony vegas 8 and the .tmp files are too big and stop my rendering, what do I do?
    Say my Local drive is called C and the amount of space in it is 20.5GB and I render a file in Sony Vegas 8 that is about 55mb, but the .tmp file ends up to be 20.5 GB and stops rendering and says there wasn’t enough space.
    I have even tried svaing it in different Drives that had more space but It still did the same thing
    Can you please help?
    Nick
    Allen Zagel replied 18 years, 1 month ago 2 Members · 1 Reply
  • Allen Zagel
    July 23, 2008 at 12:52 pm
    Hi Nick
    In the first place you should really never store video files or your render files on your C drive. That’s just asking for problems.
    In Vegas Prefs, you can specify the drive and folders for Vegas Tmp Render files as well as capture files. Capture directory is set in the capture utility.
    You should specify a 2nd HD, IMHO an internal one for all your media and rendering. Then when you finish a project, sometimes I have to go and manually empty the TMP Render folder or it will build up and fill the HD eventually.
    Were your figures just representative or are you talking a 20gb HD? No where near being big enough. I’d look for at lease a 500 or more GB HD. Prices are quite reasonable now. I have 2 external HD’s I use for storage. Seagate 750 and a MyBook 300 both FW connections.
    Also if you already have been using your C drive for rendering and file storage, you got to find the TMP Render directory and delete it and move the clips to the 2nd HD. They’re usually in the Documents folder. (that’s the default).
    Allen
    ASX Media Group, Inc.
    https://www.asxvideo.com
