Activity › Forums › Apple Final Cut Pro Legacy › Renders look worse than Pics at same size?
  • Andrew Harman
    April 5, 2011 at 11:33 pm
    There is no pro-res setting in this program.
    Thanks All
  • Chris Tompkins
    April 5, 2011 at 11:35 pm
    You posted your question in a FCP forum.
    Chris Tompkins
    Video Atlanta LLC
  • Andrew Harman
    April 5, 2011 at 11:37 pm
    Yes, i stated above that i realised in the wrong section.
    The Renders are supplied as hi-res Tiffs. we have used this renders (they are effectively pictures as are photo real) in the glossy brochures.
    I realised that i posted this in the FCP section. I am using a different program to generate the video file slideshow so there is not timeline to mention.
    Thanks All
  • Zane Barker
    [Chris Tompkins] “Did you change your settings to ProRes as suggested here?”
    Chris, Andrew said this earlier.
    [Andrew Harman] “I realised that i posted this in the FCP section. I am using a different program to generate the video”
    Considering he is NOT using FCP and has NOT said what program he is using.
    NOBODY here can help him because we don’t know what program he is using. And even if we did know there is a good chance we may not be able to help because we may not know that program.
    Why the question was even posted on a FCP forum I have no Idea.
    **Hindsight is always 1080p**
  • Zane Barker
    April 5, 2011 at 11:39 pm
    [Andrew Harman] “The Renders are supplied as hi-res Tiffs.”
    Tiffs are image files so they cannot be rendered video files.
  • Andrew Harman
    April 5, 2011 at 11:44 pm
    that is correct. the tiffs are converted to jpg’s and then used to make the slideshow which was output as a video file.
    Thanks All
Page 2 of 2
