Activity › Forums › Apple Final Cut Pro Legacy › Renders look worse than Pics at same size?
  • Renders look worse than Pics at same size?
    Posted by Andrew Harman on March 24, 2011 at 12:02 am
    I have made the slideshow from stills. Made them all 1920×1080 pixels – so all images the same. it is made up of real photos and architectural renders. Again, all the same size.
    Weird thing is, the renders, especially on the diagonal angles appear semi bitmapped where the photos, all look great.
    Why the difference?
    Thanks All
    Andrew Harman replied 15 years, 5 months ago 5 Members · 16 Replies
  • 16 Replies
  • Zane Barker
    March 24, 2011 at 12:27 am
    What are your time line settings?
    **Hindsight is always 1080p**
  • Jeff Greenberg
    March 24, 2011 at 4:20 pm
    What Zane is alluding to, is that your timeline codec will compress your stills when rendered. Depending on the timeline settings, they could look better. Try switching the timeline to ProRes and see if it takes care of the artifacts (at all.)
    Also, you should really evaluate the quality on a broadcast monitor, not your FCP preview screen (or Digital Cinema Desktop, unless it’s set to Raw)
    Best,
    Jeff G
    Apple Master Trainer | Avid Cert. Instructor DS/MC | Adobe Cert. Instructor
    You should follow me (filmgeek) on twitter. I promise to be nice.
    Come See me speak at NAB!
    Compressor Essentials from Lynda.com
    (older but still good) Marquee, Media Composer (3.5) and Basic/Advanced Color DVDs (1.0) from Vasst.com
    Contact me through my Website
  • Chris Tompkins
    March 25, 2011 at 12:02 pm
    What format are the Drawing in?
    Thin lines are usually a challenge.
    Chris Tompkins
    Video Atlanta LLC
  • Andrew Harman
    April 4, 2011 at 1:04 am
    The Renders are supplied as hi-res Tiffs. we have used this renders (they are effectively pictures as are photo real) in the glossy brochures.
    I realised that i posted this in the FCP section. I am using a different program to generate the video file slideshow so there is not timeline to mention.
    Thanks All
  • Chris Tompkins
    April 4, 2011 at 11:16 am
    Sometimes I find hi-rez files don’t do as well. Can you set the DPI of the stills down to 72 b/4 import and see how they look?
    What codec is your sequence?
    Chris Tompkins
    Video Atlanta LLC
  • Chris Tompkins
    April 4, 2011 at 11:22 am
    Walter has psoted a tutorial here on the cow on working with stills, don’t know if it relates to your issue a whole lot but might be worth taking a look @ if you haven’t:
    https://forums.creativecow.net/readpost/200/892118
    Chris Tompkins
    Video Atlanta LLC
  • Rafael Amador
    April 4, 2011 at 12:40 pm
    [Andrew Harman] “The Renders are supplied as hi-res Tiffs. we have used this renders (they are effectively pictures as are photo real) in the glossy brochures.”
    Which is your Sequence codec and your Render setting?
    Set Prores and “Render in High Precision” and “Render Motion Effects: BEST”.
    rafael
    http://www.nagavideo.com
  • Andrew Harman
    April 5, 2011 at 11:27 pm
    i had made all the pics 72 dpi and 1980×1020 before importing.
    Thanks All
  • Andrew Harman
    April 5, 2011 at 11:29 pm
    codec is H.264
    Thanks All
  • Chris Tompkins
    April 5, 2011 at 11:31 pm
    NEVER edit in H.264
    Did you change your settings to ProRes as suggested here?
    Chris Tompkins
    Video Atlanta LLC
