Activity Forums VEGAS Pro Renders HD fine for 1st 3 minutes, then stutters (Vegas Movie Studio HD Platinum 10)
  • Renders HD fine for 1st 3 minutes, then stutters (Vegas Movie Studio HD Platinum 10)
    Posted by Johan Potgieter on September 20, 2010 at 8:16 am
    Hi there,
    I am trying to render a 20 minute full HD clip on Sony Vegas Movie Studio HD Platinum 10. The rendering itself completes without a hickup. On playback, the 1st 3 minutes and about 20 seconds is perfect – the clip then starts to stutter and the sound sync seems to seperate from the video. I cannot drag the time elapsed cursor to a later footage section, or the video freezes from where I dragged the cursor – sound continues fine. I can always drag the cursor back to the 1st 3 minutes footage and that plays perfectly.
    I have tried rendering various sections of the video – the same result – whatever the footage is after about 3 minutes and a few seconds, there the trouble begins. It therefore seems as if the footage itself is not the problem. (footage at the place in the video where the problems start renders fine if that part of the video is in the 1st 3 minutes). So the problerm happens after about 3 minutes pkayback time which is after about 15 minutes rendering time on my system.
    No screensaver or sleep or anything like that interferes.
    Details:
    Windows 7 64 bit system
    6GB of RAM
    i7 920 processor
    Footage in AVCHD format (1080) and rendering to 1920x1080i 29.97fps (m2ts format). I have also made another project 3 minutes 48 seconds in total without any problems – using the exact same settings.
    Any ideas will be appreciated.
    Wilton Vargas replied 14 years, 5 months ago 5 Members · 6 Replies
  • Dale Mcclelland
    September 21, 2010 at 12:05 am
    I had the same problem with version 9 platinum, and still have it with version 10 HD Platinum. It seems to occur with AVCHD clips when rendered by Sony AVC to .m2ts files. It may be limited to Windows 7 64 bit systems, but I am not sure about that. (The few other reports I have seem from people with this problem were all using Windows 7 64 bit.)
    Earlier this year I found a solution that someone posted here (or maybe it was in another forum). It works every time for me. I routinely apply the solution for every final Sony AVC render from VMS. I don’t remember who found the solution, but I am grateful to that person. Here is what works for me:
    Run the file rendered by VMS through a program named tsmuxerGUI. It runs fast (doesn’t re-render) and somehow corrects the problem. In the tsmuxerGUI interface, add your VMS-rendered file with the “Add” button, keep all default settings except select .m2ts as the output type in the little buttons near the bottom, designate the output location where you want the file to go, and click “Start Muxing”. The resulting file should be free of stuttering and A/V sync problems.
    Of course, it is possible that your problem is being caused by something else, but I think it would be worth trying this solution.
    tsmuxer is freeware available here:
    https://www.smlabs.net/tsMuxer/tsMuxeR_1.10.6.zip
    As I recall, it doesn’t install itself in Windows or change any registry settings, it just runs from the .exe and the other files that are included in the .zip.
  • Johan Potgieter
    September 21, 2010 at 8:28 am
    SOLVED – fantastic – works beautifully and solves the problem quickly – thanks for your help and time.
    kind regards
    Johan
  • Dale Mcclelland
    September 21, 2010 at 9:18 pm
    I’m glad it worked for you. The problem has been reported to Sony Creative Software. Hopefully they will be able to determine what causes this and will fix it so the tsmuxer work-around won’t be needed.
  • Mateus Almeida
    September 25, 2010 at 7:49 pm
    Just to leave my feedback. I was having the same issues on my trial version of VMS HD Platinum 10. Windows 7 64 bits as well. My problem was also solved by using the program above. I guess sony should contact smartlabs to build this into VMS.
    BRGDS
    Mateus
  • Ron Bakker
    October 9, 2010 at 3:23 am
    Funny
    I’m having the same problem on my sv9e pro and I have window 7 64bit. Thought it might of been fixed with an update by now. Oh well good to know I am not going crazy.
    Pentium 2.4 quad|Asus P5G41C-M LX mobo|2 gig corsairs 6400 ram|Corsairs 630 power supply|Gigabyte 8800gt|2x seagate 500gig Hd’s|Lg dvd burner|windows7 premium , SV9E
  • Wilton Vargas
    March 22, 2012 at 3:08 am
    I just can’t thank you enough for sharing this solution.
    After countless renders trying to spot the problem (is it in the footage? Is it my computer? Is it some other program messing with the rendering process? Is it Vegas? Oh, wait…), I just couldn’t believe how, in no more than TWO MINUTES, BAM! Problem solved.
    THANK YOU THANK YOU THANK YOU.
