Activity › Forums › Maxon Cinema 4D › Rendering with global illumination question
  • Rendering with global illumination question
    Posted by David Alvarez on September 21, 2010 at 4:50 pm
    I am sorry to have to ask this, but I am new to rendering using global illumination. In the GI render settings, if I have it set to anything but still image, when I render out, I have a little window render over the image in the top left corner that displays the stats of each frame as it renders. I have combed through the settings but I can not seem to find where to disable this info window.
    I am feeling like an idiot. Can anyone help me with this?
    David Alvarez replied 16 years ago 2 Members · 2 Replies
  • Randy Johnson
    September 21, 2010 at 5:39 pm
    that window should not actually be on the rendered file just the preview.
    If its on the final image too you should look in the Options tab of the Render Settings Menu. You are looking for the render HUD i guess. (hud= heads up display)
    /Randy
  • David Alvarez
    September 22, 2010 at 7:48 am
    ahh you are correct. I thought i was going crazy there for a while. Thanks!
