Activity › Forums › Adobe After Effects › Rendering Video in AFX causes all .avi files to go to black or green
  • Rendering Video in AFX causes all .avi files to go to black or green
    Posted by Don Sommers on May 9, 2009 at 3:51 pm
    Hi all …. this is a strange one indeed.
    Rendering in AFX CS3 using Keylight and a garbage matte. Select RGB with Alpha using windows lossless.
    When opening the video (post render) … the audio is there, but the video is totally black. And now the strange part … ALL other avi video on the computer now either black (with audio) or green (with audio).
    Machine is Vista 64bit SP1 … windows media player 11 …i7 core/12gb ram/2 X 1TB drives/Radeon 3650 512mb card. All service packs are up to date. Running regsvr32 quartz.dll and restarting the computer allows me to view .avi’s correctly again, but as soon as I do another render, the same thing happens.
    I’ve been using AFX on the PC and Mac since V.5 … never run into this before.
    Anyone have this issue in the past … any ideas??
    Thanks in advance for any help…
    Mailind Mjoen replied 17 years, 4 months ago 2 Members · 4 Replies
  • Mailind Mjoen
    May 10, 2009 at 4:03 pm
    hi
    I have some of the same problem but in AF CS4.
    Its a HD clip with wire removal, and when I render the clip it turns either black or in my case blue.
    Its like the red color is gone.
    I have rendered the clip before but on a nother pc than the one Im working with now. also had one clip that fail and turned black then, but the problem mysteriously disappered by it self.
    now when I try to render they all turn blue.
    and I cant have a blue bachelor video:)
    mailind
  • Mailind Mjoen
    May 10, 2009 at 9:08 pm
    I figured it out!
    its the media player VLC that makes my videos blue. I tryed to play it in Windows Media Player classic and then it was normal again.
    mayby you can try that to?
    mailind
  • Don Sommers
    May 11, 2009 at 12:08 am
    Hi … thanks for the response.
    I ended up removing FFDShow from the system. I didn’t have VLC or GOM installed.
    I also changed the video back to 29.97 frames when outputting from After Effects. It had somehow chosen a 30 fps marker.
    Once I did that, .. and then rendered out the video … it shows up correctly again (very strange) in Media Player. I did come across a posting in the forum suggesting to change to 29.97.
    I’ve been too busy rendering out a large amount of clips (chromakeying) to post back my findings (sorry)… I lost about a day trying to figure out what the problem was.
    To be honest … I’m still not totally sure what it was, because I did have FFDShow running previously, and my After Effects renders were fine. So all in all, I still consider this as “unsolved” from my end … and hope it doesn’t happen again any time soon (at least not when I have a deadline).
    Thanks again for your reply…. 🙂
    Don
  • Mailind Mjoen
    May 11, 2009 at 9:45 pm
    Oh good!
    you also solved it:)
    I also removed FFDShow before I tested it in Windows Media Player.
    Have to say I am surprised that I solved it because Im quite new at this. started working with Adobe premiere and after effects about one and a half month ago for the first time.
    And I know how it is with deadlines. I have my vernisage on friday at 17.00 🙂
    best
    Mailind
