Rendering video always randomly messed up?
George Dean replied 8 years, 2 months ago 4 Members · 13 Replies
George Dean
June 28, 2018 at 5:31 pmActually reading back through your thread, the hint of the problem was in your very first post and I missed it. I was getting there, but Francois beat me to it. Whenever we have a perfect preview and a lousy render (graphics messed up), it is often the GPU causing the problem and simply turning it off will produce the desired render. Rendering speed is then often the trad off. A GPU which is optimized in the application to provide faster rendering times and reliable quality is the best fix, but then it may be a cost issue to switch out the GPU and doing so may cause an issue with some other application. Glad you got it resolved and sorry it took so long.
Best Regards……George
Francois Pénzes
June 29, 2018 at 12:28 amHi George
No need to beat yourself. From first post to solution it took less than 24 hours, with all of us chipping in, to find a solution for this lad.
Software corporations typically take longer then that…
Cheers ! And give yourself a pat on the back !
PC Win 10 Pro 64-bit 16gb Intel® Core™i7-2600k Quad Core 3.40GHz
Cameras: Canon XF305 + Canon XH-A1
Blackmagic HyperDeck Studio Mini
Vegas Pro 14, User since Vegas 3.0\’\’When the cutting stops, the editing begins…\’\’
George Dean
June 29, 2018 at 2:57 pmHi Francois,
LOL…….I wasn’t beating myself up, but Thank You. Just pointing out I missed the obvious on this one!
