Activity › Forums › VEGAS Pro › Rendering vertical issue with Sony Vegas Pro 13
  • Steve Rhoden
    July 6, 2014 at 1:02 am
    You need to have your render settings same as your Project settings!
    Steve Rhoden (Cow Leader)
    Film Maker & VFX Artist.
    Owner of Filmex Creative Media.
    Samples of my Work and Company can be seen here:
    https://www.facebook.com/FilmexCreativeMedia
  • Dristen Mcknight
    July 6, 2014 at 1:10 am
    I’m not quite sure what would be different, I’ve been doing this for quite awhile and this is the first time it’s ever happened.
    Where do I go to compare these settings?
  • John Rofrano
    July 6, 2014 at 6:00 pm
    [Dristen Mcknight] “Where do I go to compare these settings?”
    Use File | Properties… to view the project properties and File | Render As | Customize Template… to view the render properties. Make sure that the Width, Height, and Pixel aspect ratio, all match.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Dristen Mcknight
    July 7, 2014 at 12:47 am
    That fixed my issue, thank you!
  • John Rofrano
    July 7, 2014 at 12:01 pm
    [Dristen Mcknight] “That fixed my issue, thank you!”
    You’re welcome. Glad that worked for you.
    ~jr
  • Steve Rhoden
    July 7, 2014 at 3:10 pm
    Good, Always double-check those settings.
