Activity Forums VEGAS Pro Rendering Troubles – need help
  • Rendering Troubles – need help
    Posted by Dcarson on June 15, 2006 at 5:21 pm
    I have a Vegas 5 project (45 mins) that I have tried to render 3 times, and each time it stalls at the same point – 86% complete. Also, my machine has locked up each time (this never happens). Not sure what’s going on, but I have done several projects (none this large) and I have never had any trouble with rendering. Any help with this would be greatly appreciated, this is due next Wednesday!!
    Dave
    Edward Troxel replied 20 years, 3 months ago 2 Members · 5 Replies
  • Edward Troxel
    June 15, 2006 at 5:51 pm
    I would check the event that is on the timeline at the 86% spot. Perhaps you have a corrupted file.
    Edward Troxel
    JETDV Scripts
  • Dcarson
    June 15, 2006 at 5:59 pm
    Do you think it could have something to so with available space, that drive is almost full?
    Dave
  • Edward Troxel
    June 15, 2006 at 6:01 pm
    Yes it could. Also, make sure your “temp” drive has enough space as well. There are file folders listed in both File – Properties and Options – Preferences that I change because they default to someplace in “My Documents”.
    Edward Troxel
    JETDV Scripts
  • Dcarson
    June 15, 2006 at 6:08 pm
    Roughly how much space would I need to render a 45 min project?
    dcarson
  • Edward Troxel
    June 15, 2006 at 6:29 pm
    8+ Gig for the final output file plus whatever is needed for temp files.
    Edward Troxel
    JETDV Scripts
