Activity Forums Adobe After Effects rendering to fcp 5
  • rendering to fcp 5
    Posted by Nic Beery on March 15, 2006 at 10:06 pm
    i just upgraded to after effects 6.5 and the settings are slightly different when rendering for fcp 5 dvcam. i use lower setting, 29.97, dv-ntsc and there is a box that says interlace. i do it but my motion is not right when i import into fcp and play back on an ntsc sd monitor. does anyone know the settings i should use?
    thanks,
    nic
    Adolfo Rozenfeld replied 20 years, 6 months ago 3 Members · 2 Replies
  • Aharon Rabinowitz
    March 15, 2006 at 10:50 pm
    If your interlacing, make sure that you know if you are using Upper FIeld First or Lower field first -you need to decide which in the same dialog. When you bring that rendered footage into FCP, make usre it’s reading it the same way. So if you choose LFF, make sure FCP is reading it as LFF.
    Aharon Rabinowitz
    aharon(AT)yahoo(DOT)com
    http://www.allbetsareoff.com
    Creative Cow Master Series DVD
    particleIllusion Fusion Volume 1
    available @ http://www.pIllusionFusion.com
  • Adolfo Rozenfeld
    March 16, 2006 at 1:11 am
    You’re entering the options window for the Quicktime DV codec. You know what? After Effects ingnores the settings in that window (because they could be contradictory with settings in the Output module). So, you just set your Quicktime options from the Output Module window, if necesary. You could just pick the Quicktime DV NTSC 48 Khz template and you’re done.
    Adolfo Rozenfeld
    Buenos Aires – Argentina
    https://www.adolforozenfeld.com
    adolfo(AT)adolforozenfeld.com
