Activity › Forums › VEGAS Pro › rendering to aspect ratio of 16:9
  • rendering to aspect ratio of 16:9
    Posted by John O flaherty on November 13, 2012 at 12:07 pm
    Hi Guys,
    i have a project almost finished and usually render as mpeg2 720 X 576 25fps, but i have been informed that it should be 16:9 unfortunatley i only VEGAS 6, is there an easy way to make the output file 16:9, is 16:9 widescreen? any help appricated. john
    John Rofrano replied 13 years, 10 months ago 4 Members · 9 Replies
  • 9 Replies
  • Jeff Schroeder
    November 13, 2012 at 5:21 pm
    See if you have a template in your list for “widescreen” Otherwise change the pixel aspect ratio within the regular temple template.
    2-Xeon X5680 @ 3.33, EVGA SR-2 Mobo, 48GB DDR3, GTX 580 3072MB, 16TB Attached Storage, Win7, Vegas 11 x64
  • John Rofrano
    November 14, 2012 at 1:37 am
    There is no way to simply render a 4:3 project as 16:9 and have it be acceptable because it will have huge black bars on either side. You really should change your project properties to PAL DV Widescreen (720×576, 25.000 fps) and go back and crop all of your events to match the 16:9 aspect.
    If you don’t have time to do that, you can create a new project with the properties set to PAL DV Widescreen (720×576, 25.000 fps) and drop your 4:3 project in it as nested veg file. Then go into Pan/Crop and right-click the frame and select Match Output Aspect. This will crop your entire 4:3 project to 16:9 but you may be cutting off heads to you’ll need to go back and make sure to keyframe the crop where needed. Then you can render as 16:9 and have it look correct.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Thayalan Paramasawam
    November 14, 2012 at 10:04 am
    Hi Sir,
    Some times i use tmpegenc dvd authoring for author dvd,What is defrend pixel 12:11(4:3) and display 4:3.Before i start to author the dvd which render by svp 11,i must set the aspect ratio.
    Thank You
  • John Rofrano
    November 14, 2012 at 4:45 pm
    [Thayalan Paramasawam] “Some times i use tmpegenc dvd authoring for author dvd,What is defrend pixel 12:11(4:3) and display 4:3.Before i start to author the dvd which render by svp 11,i must set the aspect ratio.”
    Sorry I really don’t understand your question. Are you somehow making 12:11 videos instead of 16:9?
    ~jr
    November 14, 2012 at 6:01 pm
    November 14, 2012 at 6:08 pm
    Hi Sir,
    For dvd which setting (Aspect Ratio) should i use….
    Pls help me on this matter Mr.John Rofrano.
    Thank You
  • John O flaherty
    November 15, 2012 at 7:12 pm
    guys as always thank you so much for all your help and advice, im gonna go into event pan crop for all clips, from drop down list change to 16:9 and readjust any clips that might need readjusting and then render as standard pal 720 x 576 i have do a few tests and it seems to look good for widescreen, many thanks again. john unless there is an easy way that i can foillow, sometimes the advice on here is brillant but beyond me technically, put i only have version 6 so might be limited
  • John O flaherty
    November 15, 2012 at 8:19 pm
    many thanks john, might try this also.
  • John Rofrano
    November 16, 2012 at 10:37 pm
    [john o flaherty] “many thanks john, might try this also.”
    You’re welcome. Let us know how you make out.
    ~jr
