Activity Forums Apple Final Cut Pro Legacy Rendering Timelines
  • Rendering Timelines
    Posted by Eric Martin on March 29, 2006 at 8:31 pm
    Why do I have to render a seqence/timeline every time, even when the TL settings match the video (720 x 480)
    in this case)? I’ve changed the variables (anamorphic, square/D1, etc), but it always wants me to render.
    Tom Meegan replied 20 years, 5 months ago 2 Members · 1 Reply
  • Tom Meegan
    March 29, 2006 at 8:45 pm
    Eric,
    I’ve been through this many times, and I have believed, as you do, that everything matched, but each time I’ve eventually found that there was something I over looked.
    I know that is a lousy answer when you are suffering, but there are a lot of variables, and a few traps.
    Sometimes I find it is best to start fresh with an easy set-up and a test capture into a fresh project/sequence. If this works, then compare it everything in your project in progress.
    Post back with more information if you need to.
    Best of luck.
    Tom
