Activity Forums VEGAS Pro Rendering Templates sugestion
  • Rendering Templates sugestion
    Posted by Frank Stevn on April 9, 2013 at 8:15 pm
    I got these requirements for delivering content. I need your suggestions on what template use to render.
    1. First:
    • Create Content at 1920(w) x 1080(h)
    Square Pixels
    • XVID Compression
    • 30 Frames/Second
    2. Second:
    • Create Content at 1920(w) x 1080(h) Square
    Pixels
    • HuffYUV AVI Compression with Alpha Channel
    • 30 fps
    Steve Rhoden replied 13 years, 5 months ago 3 Members · 11 Replies
  • 11 Replies
  • Frank Stevn
    April 9, 2013 at 10:03 pm
    I can’t find xvid in Vegas 12
    Should I download it form here https://www.xvid.org/
    Is it safe to install this codec?
    Any tips on how to use it?
  • Stephen Mann
    April 10, 2013 at 3:31 am
    Xvid and DivX are display formats and not supported by Vegas. If you are stuck with Xvid or Divx footage to edit, the solution is to not use Xvid or DivX. Convert the files with something like AviDemux to a format like Motion-JPEG video with PCM audio and the files should edit fine.
    Steve Mann
    MannMade Digital Video
    http://www.mmdv.com
  • Steve Rhoden
    April 10, 2013 at 8:00 am
    Delivering this content, what are they
    gonna do with the video (where is it destined)?
    Steve Rhoden
    (Cow Leader)
    Film Editor & Compositor.
    Filmex Creative Media.
    https://www.facebook.com/FilmexCreativeMedia
    1-876-832-4956
  • Frank Stevn
    April 10, 2013 at 11:53 am
    I don’t need to edit the video in vegas 12.
    I need to deliver the video with XVID Compression, using Vegas 12.
    They will use the videos to display advertising in areas of a screen. (In a sport stadium digital signage system.)
  • Steve Rhoden
    April 10, 2013 at 1:47 pm
    Well if thats the case, you can download the XVID codec and render
    as normal, selecting it in the Customized option in the render que.
    Steve Rhoden
    (Cow Leader)
    1-876-832-4956
  • Frank Stevn
    April 10, 2013 at 2:01 pm
    Thanks. I did it. Downloaded the XVID codec and rendered OK.
    Now I have a second request:
    I downloaded HuffYUV codec, but it doesn’t shows up under windows video.
    Any ideas?
  • Steve Rhoden
    April 10, 2013 at 2:13 pm
    Choose a different Render format then and see if the option
    to select HuffYUV Codec comes up in the template.
    Steve Rhoden
    (Cow Leader)
    1-876-832-4956
  • Frank Stevn
    April 10, 2013 at 2:34 pm
    Thanks Steve for your time.
    I wasn’t able to find HuffYUV in vegas.
    I downloaded Virtualdub and was able to render Uncompressed AVI from vegas into AVI-HuffYUV.
  • Steve Rhoden
    April 10, 2013 at 9:41 pm
    I would have thought the option to choose it, should be available if
    you choose the Video for Windows format.
    Steve Rhoden
    (Cow Leader)
    1-876-832-4956
  • Frank Stevn
    April 10, 2013 at 10:00 pm
    Definitely HuffYUV doesn’t shows up in vegas-12 (64bits).
    I tried Vegas-10 (32bits) and I was able to render HuffYUV AVI with less size and more quality than the one rendered in Virtualdub.
