Activity Forums Apple Final Cut Pro Legacy Rendering speed – Qmaster
  • Rendering speed – Qmaster
    Posted by Javad Ahmadi on June 20, 2008 at 10:03 pm
    Hello Everyone!
    My macpro is:
    Processor Name: Quad-Core Intel Xeon
    Processor Speed: 3 GHz
    Number Of Processors: 2
    Total Number Of Cores: 8
    L2 Cache (per processor): 8 MB
    Memory: 8 GB
    Bus Speed: 1.33 GHz
    I watched the Qmaster video tutorial on Creativecow and few others. I followed exactly the right procedure, but I can not get the maximum speed on when I render with Apple compressor. My activity monitor is jumping no more the 30%. I tried all combinations but it can not get any better.
    Can some one help me.
    I really appreciate it.
    Javad
    Javad Ahmadi replied 18 years, 2 months ago 3 Members · 4 Replies
  • Russell Lasson
    June 20, 2008 at 10:13 pm
    What’s your storage system?
    What type of files are you compressing?
    What format are you compressing to?
    Are you compressing out of FCP to Compressor?
    -Russ
    Russell Lasson
    Kaleidoscope Pictures
    Provo, UT
  • Javad Ahmadi
    June 20, 2008 at 10:29 pm
    Hi Russ;
    I have 2 internal drives. I normally render from main drive to my second drive. Types of files I render are DV NTSC to DV PAL or revers, NTSC to quicktime for web, Final cut sequence to (simple and complex) to DV NTSC.
    Sometimes I find it much faster if I output my Final seq. to DV NTSC for example and then use the completed quicktime file for various out put format using compressor.
    I hope I answered your questions.
  • Lars Fuchs
    June 21, 2008 at 7:51 pm
    Could you perhaps post a link to the tutorial you mention? I’ve done several searches and come up empty.
  • Javad Ahmadi
    July 3, 2008 at 12:16 pm
    Hi Lars;
    I solved my problem with Larry’s advise.
    check this link.
    https://www.larryjordan.biz/articles/lj_compressor_multi-processor.html
    On CreativeCow’s site, there was a tutorial from Ben Scott. I could not find it anymore. I may have it saved somewhere, if you like I can dig and look for it.
    cheers
