Activity Forums VEGAS Pro Rendering so slowly
  • Rendering so slowly
    Posted by Dáithí Cinnsealach on April 28, 2016 at 1:08 pm
    Okay, so I’ve just upgraded from Movie Maker. Rendering takes 3 hours for a 13 minute video. It’s 1920×1080, 30 fps, set to best, using openCL. I also have it prioritised on cpu, as I thought that would help. It not a very powerful laptop I have, but should it be that slow? I had set it to good rendering yesterday, but didn’t use the graphics card nor did I set the cpu usage to high in task manager. Any help?
    John Rofrano replied 10 years, 4 months ago 2 Members · 1 Reply
  • John Rofrano
    April 29, 2016 at 11:25 pm
    [Dáithí Cinnsealach] “set to best,”
    Unless you are resizing the video, you can change Best to Good and get the SAME quality in HALF the time. There is a reason that Good is the default. You don’t need to use Best unless you are resizing (e.g,., HD to SD) and it takes twice as long.
    ~jr
    http://www.johnrofrano.com
    http://www.vasstsoftware.com
