Activity Forums Adobe After Effects rendering smaller size review copy of ultra-wide production
  • rendering smaller size review copy of ultra-wide production
    Posted by Rick Godin on June 28, 2005 at 1:32 am
    I am working on a panoramic production, 12×54 foot projected from high res stills. I am working with a 2280x720HD composition layout which will be rendered, then cropped into 3 separate HD streams. My question, which is probably one of those slap yourself upside the head ones, but how can I take my 2280×720 composition and render it out at 720×160 or so for review? When I resize the comp, I end up cropping the images. AE does so much so well, don’t know why I can’t find answer to this (simple) task. Thanks for the brain fix. rg
    Rick Godin replied 21 years, 2 months ago 3 Members · 3 Replies
  • Andy Stokes
    June 28, 2005 at 9:41 am
    Hi Rick,
    Create a 720×240 comp then drop your 2280×720 comp into that and scale to 33.3%
    That should do it.. OR am I missing something ?
    Cheers,
    Andy
  • Josh Michnik
    June 28, 2005 at 11:38 am
    or when you render it out
    in the output module, click on lossless
    then click the stretch.
    and you can size it to whatever you want…just for a render preview.
    easiest way.
    you can scale it to whatever and keep the same aspect ratio
  • Rick Godin
    June 30, 2005 at 3:00 am
    Thanks so much. One of those very simple process procedures that everyone must know, but I couldn’t figure out through the book. rg
