Activity Forums VEGAS Pro Rendering settings (Vegas pro 9.0)
  • Rendering settings (Vegas pro 9.0)
    Posted by James Fox on October 2, 2010 at 7:06 pm
    When I already thought I began to understand which settings I have to choose while rendering video file, I am still pretty confused.
    1) Does changing aspect ratio changes video resolutsion? Me myself thought that it will, but while rendering with Vegas, according to mediainfo it doesnt.
    2) Does changing aspect ratio affects video quality? For example from 4:3 to 16:19
    3) Should I set Project Properties before editing, or all this can be done after editing without any problems?
    4) Can I copy exact source clips settings and render edited movie with same settings?
    My source is here:
    General
    Complete name : C:\Users\admin\Desktop\101PNV01\M2U01097.MPG
    Format : MPEG-PS
    File size : 10.8 MiB
    Duration : 9s 568ms
    Overall bit rate : 9 425 Kbps
    Video
    Format : MPEG Video
    Format version : Version 2
    Format profile : Main@Main
    Format settings, BVOP : Yes
    Format settings, Matrix : Default
    Format settings, GOP : M=3, N=12
    Duration : 9s 520ms
    Bit rate mode : Variable
    Bit rate : 9 100 Kbps
    Width : 720 pixels
    Height : 576 pixels
    Display aspect ratio : 16:9
    Frame rate : 25.000 fps
    Standard : PAL
    Color space : YUV
    Chroma subsampling : 4:2:0
    Bit depth : 8 bits
    Scan type : Interlaced
    Scan order : Top Field First
    Bits/(Pixel*Frame) : 0.878
    Stream size : 10.2 MiB (95%)
    Audio
    Format : AC-3
    Format/Info : Audio Coding 3
    Mode extension : CM (complete main)
    Duration : 9s 568ms
    Bit rate mode : Constant
    Bit rate : 256 Kbps
    Channel(s) : 2 channels
    Channel positions : Front: L R
    Sampling rate : 48.0 KHz
    Bit depth : 16 bits
    Video delay : -80ms
    Stream size : 299 KiB (3%)
    Which would be best settings for rendering? I tried to render it in AVC to get a small file size, but some how i got output aspect ratio 2.222, through I set it to 16/9 (so 1.77778).
    Many thanks,
    James
    Ilya Kutuzov replied 15 years, 11 months ago 2 Members · 1 Reply
  • Ilya Kutuzov
    October 3, 2010 at 9:15 pm
    For all i know:
    1)
    unless you crop the source image to cut out 16:9 from 4:3 or vice versa, changing aspect ratio should not affect the resolution.
    2)
    what exactly is the video quality? it comes from two things: the camera matrix resolution and the way your camera stores the footage. after you have your footage captured to a PC, in any aspect ratio, see (1).
    3)
    Proj Props affect the way you see the preview. However, when you want to deinterlace properly, or adjust between different ratios from different sources, or get a flawless audio preview, PP is where you set the parameters. you do it before editing – you edit properly adjusted material. you can change any param in PPwhenever you want. play with it, take a 4:3 footage and make the PP 16:9, see what happens. use Crop image to get a 16:9 picture out of a 4:3, and see what happens to the resolution – by and large, any software zoom will result in a worse picture unless the source is HD and the project is in DV resolution.
    Good example for that – the interlace thing.
    Remember, when you want to preview and consequently render an interlaced source as progressive, select both “progresive” AND a deinterlace method (blend fields suits 90% of your needs, sometimes a specific kind of movement is better done by interpolate).
    Also, I recommend to match the interlace params in PP and Rendering params to get pure deinterlace if you want a progressive result. If you render your footage to be viewed on a TV, you should leave the interlace both in PP and when rendering.
    4)
    Connected to (3). right click at a source clip in Meida bins or on the timeline and read the media params. compare them to your Proj Props. you’ll see what you can keep.
    But the thing is why you’d want to keep or change anything. Example, slow motion. I had to produce a 20% speed slomo for PAL (25 fps) 16:9 progressive output from NTSC 4:3 source (29 fps). To get a sensible slomo – as good as the source may allow – I had to switch on the Disable Resampling radio button in source clip properties. This thing does not appear in Proj Props and whatever i did in PP never changed the slomo quality. So mind those little things, it’s easy to figure out what does what.
