Activity Forums VEGAS Pro Rendering Question
  • Rendering Question
    Posted by Joe Minnella on June 5, 2009 at 5:20 am
    Hi Everyone,
    I’m cutting a feature length on Vegas 8.0. I shot the film on a Canon XH-A1 in 24F-HD. I guess I really have a question and an issue.
    First, can anyone recommend the best render settings to show the highest quality DVD?
    As I’ve been rendering rough cuts, it seems to cut the movie into seperate files or pieces. It cuts every 18 minutes and 46 seconds. Can anyone tell me how to get it to render to just one single movie file?
    Thank you for any help you can offer!!
    John Rofrano replied 17 years, 3 months ago 2 Members · 3 Replies
  • John Rofrano
    June 5, 2009 at 10:55 am
    It sounds like you are rendering to a drive that is formatted for FAT32 and you are hitting the 4GB file size limit. You need to use NTFS drives for rendering or convert that drive to NTFS.
    As for the best DVD render format, I would use the MPEG-2 DVD Architect 24p NTSC Widescreen video stream template and render the audio separately as Dolby Digital AC3 either Stereo DVD or 5.1 Surround depending on the audio in your project.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Joe Minnella
    June 8, 2009 at 6:45 pm
    Thank you so much for your response. After editing a full feature, I feel pretty stupid not remembering that my external harddrive would cut my off after 4 gigs. I cleared some room on the computer’s harddrive, and it did the trick first try. Again, thank you!!
    As far as rendering audio and video seperately, how does that actually work? Do I need to render those seperate files back together? Or can that be done in dvd setup?
    Also, I’d like to work on the project in pro tools before finalizing the sound anyways. Is there any way to render the project with seperate sound files for each line of audio in my project rather than merging it all into 1 sound file?
    Thank you in advance!
  • John Rofrano
    June 10, 2009 at 10:51 am
    You render the separate files but give them the same name, just with different extensions (.mpg & .ac3). When DVD Architect sees an mpg file with no audio, it looks for an ac3 file with the same name and if it finds it, it will automatically pull it in as the audio.
    Yup, you want to use our free plug-in VASST Trackalizer. I wrote it specifically for this purpose. The installer hasn’t been updated for Vegas Pro 9.0 yet but I see you are still using Vegas Pro 8.0 so it should work fine.
    ~jr
