Activity Forums Adobe After Effects Rendering quality is hardware dependent or not
  • Rendering quality is hardware dependent or not
    Posted by Mandeep Singh on November 26, 2009 at 6:46 am
    Hello my question is very basic. I want to ask that if i render a composition on my laptop which has no expensive card , and if i render the composition on a workstation having a video card like blackmagic , will both renders be the same quality renders or will they differ ??
    Or simply putting is the ae rendering Quality dependent upon hardware and if it is will it produce different quality outputs on different computers.
    Conrad Olson replied 16 years, 10 months ago 2 Members · 1 Reply
  • Conrad Olson
    November 26, 2009 at 4:07 pm
    The render will be identical, it will just probably take longer.
    You just need to make sure you have the same plug-ins and fonts installed on both machines.
