Activity Forums Adobe After Effects Rendering Problems with Invigorator layers
  • Rendering Problems with Invigorator layers
    Posted by Sura Shote on March 4, 2006 at 12:24 am
    Each time I try to render my project, it stops after a few frames. Then I noticed that if I turn off the invigorator layers (about 3), the comp renders. But once I turn on the Invigorator layers, the rendering just crashes.
    Pls any tip?
    John Dickinson replied 20 years, 6 months ago 2 Members · 1 Reply
  • John Dickinson
    March 4, 2006 at 2:51 am
    What version of Invigorator are you using? Check on the Zaxwerks site and install the update if need be. If that doesn’t fix your problem try posting on the Zaxwerks forum here at the COW and Matt or Zax may have some answers.
    JD
    John Dickinson
    Motionworks
    http://www.motionworks.com.au
