Activity › Forums › Apple Final Cut Pro Legacy › rendering problems on final cut pro
  • rendering problems on final cut pro
    Posted by Lenny S on April 27, 2007 at 2:47 am
    I’m working on a video project and i finished a portion of it & I’m having a massive problem I was hoping you might help me with.
    I’ve been working on it for several months with Final Cut Pro 4 on a Mac & it’s saved on a external hard drive. It was rendering fine all along. Now all of a sudden it’s not rendering at all. I hit all the render options & the window just flashes by really fast & does nothing. it wouldn’t be that much of a problem except i’m trying to make a real time copy to dvd but during playback it drops frames & stops.
    would you have any ideas/sugestions as to what might be wrong & what i might do to fix it? I’d really appreciate any help!
    Lenny
    Lenny S replied 19 years, 5 months ago 2 Members · 2 Replies
  • Dan Riley
    April 27, 2007 at 3:47 am
    Try deleting all your present render files and have FCP
    re render everything. If you’ve been working on this project for a while
    you need to clear out the old render files. This is not unusual.
    Just go into your render folder and trash all the files there.
    Dan
  • Lenny S
    May 1, 2007 at 3:16 am
    Thanks for responding. I just tried getting rid of the render files & it didn’t work. I also tried cleaning out the hard drive a well as the Mac I’m working on. I went thru the manual for final cut & they had nothing on how to troubleshoot something like this. I’m stuck as what to do next & it pretty much is ruining the whole project as the frames keep dropping every time I play it or attempt to record it into a camcorder.
    any other ideas will be very much appreciated.
    thanks!
    Lenny
