Activity Forums Adobe After Effects Rendering Problems
  • Darby Edelen
    March 15, 2008 at 8:51 pm
    More information is necessary. What did you try to do? What kinds of layers are in your composition? What do you mean by ‘stuff like particles’? Were they particles, or did it just look like your video was entirely distorted? Help us narrow down the potential problems.
    Darby Edelen
    Designer
    Left Coast Digital
    Santa Cruz, CA
  • Er Bin hao
    March 16, 2008 at 2:06 am
    I was trying to recreate the animation of Andrew Kramer’s Advanced Camera Techniques with the particles bursting out.
    I added text beside the particles and when i rendered, the text did not show up clearly but appeared from blurred to nothing at all.
  • Darby Edelen
    March 16, 2008 at 10:19 pm
    [Er Bin Hao] “the text did not show up clearly but appeared from blurred to nothing at all. “
    Sounds like it might be a problem with the Depth of Field that AK used in that tutorial, a lot of people had similar trouble. He uses DOF to blur the particles, but turns Draft 3D mode on to keep the text from blurring, however when you render the default is to render in Full 3D. You’ll need to set your render settings to use Draft 3D.
    Darby Edelen
    Designer
    Left Coast Digital
    Santa Cruz, CA
  • Marco Estrada
    July 21, 2008 at 3:32 pm
    Hello, I have the same problem with my render.
    The problem now is that I don´t know where to set “draft 3d” in my render settings.
    Can anyone help me, please.
    Thanks!!!
