Activity Forums Adobe After Effects rendering problems.
  • rendering problems.
    Posted by Letitbleed on August 16, 2005 at 10:49 pm
    Hi I did ae benchmark renders and it went way faster and those have to be more intense than the sand tutorial. One thing I noticed is it used like 1.5 gigs of memory and when I try to render it uses maybe 90,000k and that’s it? The psd sequence took maybe a minute and the quicktime burning man video took an hour. If I download the ae file associated with the sand tutorial and render it goes faster….but when I try to do it from scratch, that’s when I run into my rendering problem. I’m running a P4 at 3.4 ghz and have 2 gigs of ram. Which is three times faster and 4 times more ram than the other machine that I had rendering the tutorial in about an hour…So I have to be doing something wrong. I’ve tried the psd sequence with a render farm setup with another computer and that one takes a long time too. I’ve also tried the quicktime render and it takes the same amount of time. Any suggestions? Thanks again.
    LIB
    Letitbleed replied 21 years, 1 month ago 1 Member · 0 Replies
  • 0 Replies
